Opinion on Fox Podium 1.5 front shocks
fulltimer
Am asking a question in what I think will be a future need. I didn't ask this question before I bought my Elkas and regret that.
I think that in the not to distant future my Elkas will fail again and am I looking at replacing the fronts with the Fox shocks. This model has been suggested to me by a very trustworthy source but I am wondering if I can get any "reports from the field" of anyone who may have them on an RT or ST.
Thanks in advance.
Ive been thinking about Elkas bc they are adjustable but I wonder if theyre still having the leaking problem.The Fox shocks arent adjustable,correct?Are your shocks newer units or older?
Thanks in advance.
I would advise not getting them..the springs are very soft/weak...I would call M2 Shocks...much better...for a few dollars more.. you get a much better product..
Interesting reply. Our Can Am accessory shocks have firm springs that compliment the internal valving. Fox retailed for a few bucks over $500 for the pair of front shocks. M2 is about double that.
You are right they are double...but... you get what you pay for...a much better quality product.
Shocks Tires Oil Seats all in the eye of the Beholder. Depends a lot on how and where you ride. I personally would never buy another Elka. I had the Fox Podium 1.5 on my F3S and liked them a lot Rode with my friend he put his Elka stage 5 on and took them off and went back to Fox Podium 1.5's. Good luck with Your choice!
Longtime friend purchased a M2 for his motorcycle. Based his choice on various things, but a lot was what he had read about them. He has already had to send it back a few times because it was incorrectly setup. He thinks after three tries it may now work. M2 apparently put the blame on the guys in the shop.
Those shocks do look promising, but are very expensive, possibly Spyder shocks are not having similar issues. My friends M2 was for his race bike and he knew not to ride it as it was that far off. Guessing, next setup he will have me revalve it when needed.
It's to bad the Elka's still having a leaking problem, would think that they would have it fixed by now!! I wonder how many other people out here are having the problem, or is it a isolated case!:dontknow:
Good thing I saw this, I was just considering getting an Elka for the rear. The PO of my '14 put the Fox shocks on the front and yes, they're adjustable. Since I don't have anything to compare them to I can't say if they're better/worse than anything else, but they look like they've been on there a while and no leaks.
If the M2s are twice the price, not sure I can go there.
I haven't read anything much about the newer Elka's having a seal leak. I know they had a bad run a few years ago. I had a pair of those. However, once I took them to my local suspension guy, he was able to fix them and I never had any issues with them afterwards. It was totally annoying and did cost $$, since they were outside of the warranty period, but they do work brilliantly.
The manufacturer does recommend getting them serviced regularly, so some of the leaks could be from people who aren't doing the regular servicing.
Exactly!
I beg to differ. I have 21k VERY HARD miles on mine and with proper adjustment (and a recheck for sag every so often) they still feel like new! In fact, as a test, I put too much preload on the springs for kicks and giggles and the suspension would "hop" over bumps.... that tells you the springs have more than enough "spring rate"! And on top of it all, no leaks, no fade and they work in PERFECT harmony with the Fox R2 I have out back.... :bowdown::yes:
Thanks in advance.
Ive had Fox shocks on the front of my 2013 STS (not sure the same type Fox you are referring to) for 7 years 18,000 miles. I’ve had one go bad about 3 years ago, not sure why. No other problems since. I know that’s not many miles for some of you though.
These are about 3 years old. The first repair was done by their west coast service center. The 2nd and 3rd was done by SDHQ in Gilber , AZ. From what I could find out they have a reputation for knowing what they are doing.
Thanks for the info from all of you. We will just see what the future holds for these.
Exactly!
That's fine for one up riding..you go two up.. different story...the fox bottom out...I'm glad the fox works out for you ...but for me....nope!!...this is for the rear..the front springs is soft too...I hit the brakes hard it dives... everyone is different..and that was my experience..and I got rid of them.
So just to be clear, the consensus is that the stock Fox podium shocks are comparable/just as good to the problematic Elka’s? The Fox Podium 1.5 shock’s are stock right?
Nope .. The F3-S has Fox Podium fronts and generic soft rear. Podium 1.5's are a $850 upgrade for the front and the Podium 2 rear is $970.
Has anyone taken a measurement of the oem Fox Podium shocks to check the body diameter.
Pretty certain the aftermarket shocks got the Kashima coatings. If oem is 1.5, then guessing maybe a shim stack change on the valving and possible spring change.
FWIW, Kashima is nice but not truly needed unless pushing the extreme limits of grip constantly.
There really are so few of us!! I know my wingman wonders if there is actually something wrong with me..... :roflblack: ;):yes:
PMK....I don't know what the diameter is compared..but the new ones are larger...and the springs.
Measure the diameter of the shock body, that should be how they determine the 1.5 series. Maybe its the photo, but both shocks appear to be the same diameter of the body.
As for springs, yes they appear different. Spring perch changes are often done with firmer springs and must be done with larger springs.
Is the 1.5 running a Fox spring or a BRP spring?
