Only have Left Turn Signal blinkers! Any ideas?
VegasDon
Hello
i have a 2008 sm5, i only have left turn signal blinkers , the handle bar switch is new and did not fix the problem, i turn on left turn the left turn light flash, i turn on the right turn and only the left side flashes , all light flash with the hazards , there are not any burn out bulbs, no work was done just started doing this one day, i can use any help i can get to help find the problem,,, right know i seem to be going in circles
thanks
Kinda narrowed it down
The switch may be new but sounds like a loose connection, Especially if all work with hazards. Just for testing try pushing in (cancel) as you toggle L/R
