Don't know what the situation is over there in Oz but here in the US there are VERY FEW car tires available in the OEM size. That's why you see so much discussion about what tires fit best. Generally speaking, a 215/60/R15 is a very good size choice for the rear.I would like to stick to standard if possible as you are pretty much assured they will fit.
Hi Glennm,
Were you going to mount the tyres yourself, or get a tyre shop to do it? I only ask as I got very excited about the number of tyre options, went to my tyre guy, only to find that many of them were no longer available. (He was quite happy to get any brand I wanted).
The best solution for me was to get him to order the best all round tyre he knew of in the specific sizes, as ANY aftermarket is better than the Kenda/Arachnid for me. That also gave him a bit of profit on the tyre purchase, which I thought was fair. He got a bit of a shock when he saw the “special motorcycle” stamp on the Kendas, but was fine with it when he saw the J type car rim underneath. There are SOME tyre places though that will refuse to mount an aftermarket car tyre on a Spyder.....worried about the “special motorcycle” stamp, I’d imagine. The easiest tyre to get was the Kuhmo Ecsta.... very happy with them.
Pete
"I would like to stick to standard if possible as you are pretty much assured they will fit"
not a good surmise
tyres can have the same numbers but have diff OD's
are we talking 14's or 15's
gets expensive if you get it wrong:banghead:
russ
I had two Nankang AS-1's (same size as the OEM Kenda's ) fitted to the front of my 17 RTL yesterday, as close a match to the Nankang XR611 (same size as the OEM Kenda) rear as I could get. I've put about 130kms on them and agree with Peter, anything appears to improve on the OEMs.
You've possibly already read my write up on the XR611 https://www.spyderlovers.com/forums/showthread.php?124948-Nankang-XR611-Rear-225-50R15-fitted-to-RTL&highlight=nankang
Glennm,
You mention Kuhmo.......just another heads up. You will see some negative comments about the Kuhmo performance in the wet from some American riders. That does not appear to be the case out here. I have had zero issues in the wet, and Zoom Zoom Aawens, who rides much harder than me, has also reported zero issues. Perhaps we use a different road mix to the US?
Pete
...... I think someone said they were ASymmetrical
. What does that mean.....
As you know many riders of conventional trikes mount the front tire in reverse of normal. This is because the front tire is pushed instead of doing the pushing. This supposedly maximizes the traction aspect of the tire for turning, etc. I wonder if there would be any similar benefit to mounting Spyder front tires to run reverse of their specified direction of rotation. Or is the pushing traction already factored into the OEM Kenda fronts?Oh, btw, Asymetric &/or Directional tires aren't usually an issue up the front (running the correct way of course, &/or at least knowingly running the 'wrong' way for a suitable reason!) of your Spyder, and they aren't necessarily too much of an issue on the rear either, altho you do want to make sure that an asymetric &/or directional tire run on the rear of your Spyder is suitable for use as a drive tire and that it's also running in the correct direction! There's not really gonna be any 'suitable reason' for running a directional drive tire the wrong way :lecturef_smilie:
IdahoMtnSpyder, that is a very good question. Perhaps Peter Aawen and/or Blueknight911 can answer that for us.
