On my Spyder; Limp Home Mode, DPS failure, VSS, and CEL on the way home tonight..
I would also get the numbers off of all the relays and buy one more of each.
I believe with the numbers you could try auto nation and or NAPA to carry around some spares just in case.
Northramp
Can someone post a pic of their fuse box...I've never looked for it before to take a peek and see what surprises I'll find in mine! thanks...
Ask and you shall receive. :D
Front of the Spyder with the trunk open.
Fuse box location with trim panel in place.
Fuse box location with trim panel removed.
Fuse box with cover removed. Three relays on the right (black rectangular shaped objects) and one relay on the left (large gray square object).
Close up of inside of fuse box cover with the relay indentations in the factory installed foam and spare fuses. I guess they started putting foam inside the cover fairly early on as I have a Premier Edition (#3783) delivered March of 2008.
There is a second fuse location under the seat on the right side of the bike.
Closer photo of the underseat fuse box. The fuses under here are considered "main" fuses I believe and are a different style than the fuses in the front fuse box. They are called JCASE (style) fuses.
