Some Guy
Silly girl...that's not the kitchen. :doorag:
Oooo...that one could get you hurt!!! :roflblack:
That's true, I could have you fix it, but I'll never learn how to do things if I don't even try![]()
If youn need a tool once, you will probably need it again. I would get a good quality tool and add it to my tool collection:thumbup:. At some point in the future you will have all the tools you need (and they will be of high quality)Limited as in tools from Harbor Freight usually only work once.... ;-).
...I made a template and cut some black molded gutter guard to fit. Held it in place with clear silicone rubber sealant.
What else is a kitchen used for?????:dontknow:
sent using Tapatalk.
Well if you like fixin things. Lets see I need... rear tire replaced, new Y gaskets, 12000 mile service. I'm sure I could think of a couple of other things....Or ya could wait till you come up this weekend and let me fix it for ya..... I know right where MY dremel is.......![]()
Nice touch Tina, the screen looks great.Well ----- Mr. G-Man, as a matter of fact, I did spend time in the kitchen.hyea: That's where I made the grill cover for the right side panel. I made a template and cut some black molded gutter guard to fit. Held it in place with clear silicone rubber sealant.
Well if you like fixin things. Lets see I need... rear tire replaced, new Y gaskets, 12000 mile service. I'm sure I could think of a couple of other things....![]()
No doubt in your abilities. Just couldn't pass the chance at a poke.
Firefly will take the beating. (Thanks for stepping up Firefly) :doorag:
Now that's an Idea I'm going to try. Been considering screening off the RH side blowtorch outlet but the ones I've seen are rather pricey.
Patrick
