oil
bmccaffrey
I need to add oil to my reservoir.
Can i use another brand or do i need to use the xps. Ok to mix???
Thanks in advance:yes::yes:
Yeah..!!
you can as long as they have the same spec's. Try to stay with the same kind and weight, in this case a synthetic blend. But if you are out and selection is poor you can add others and change your oil when you get back..:thumbup:
Absolutely, as long as its the proper weight and a motorcycle oil. Makes no diff if its all syn or a blend (which is prob what you have in it now).
As seems to be the unanimous response, yes, it's fine to mix as long as you use the correct JASO rated oil and are close to the same viscosity and at least a blended oil, if not full synthetic. If anything, try not to go lower than the upper number (40). But it won't hurt to go to 50 on the upper number.
