Oil Sump Capacity
A1A
Anyone know the oil sump capacity for the ACE 1330 3-cyl SE6 as showen in the shop manual?:dontknow:
2nd Oil Change at 10,000 miles
Completed 2nd oil change with filter recently. I used the "recommended oil quantity" per Lamont's chart (http://www.spyderlovers.com/forums/s...il-recommended Post 13) below:
Less oil recommended per chart below:
attachment.php
4.7L = 5 quarts and that's what I put into the engine. Just got back from a 30 mile run and checked oil level.
FYI - oil level on dipstick: It is showing at the "low" mark on the dipstick.
Since the 2014 RT has been AWESOME and has not used a drop of oil, I will monitor this level and insure it does not go below that mark. IF this is the new recommended oil level, then why do we use "old" measuring dipsticks. It would seem a new dipstick by BRP is in order here to insure we follow proper oil levels in our engines on the 1330's. IMHO !
Thanks for the response folks!:thumbup: My bad,:opps: I meant to say. what is the Oil Tank Capacity in accordance with the shop manuel?
Useful information is always appreciated. I just wish they would go to a more modern spin-on oil filter. Anything that simplifies doing oil changes is also appreciated.
