jcthorne
Well-known member
I am thinking I would like to replace the factory fuel level and temp gauges with oil pressure and volt meter, letting the factory electronic gauges in the LCD handle fuel and temp.
Would like gauges with 270deg sweep and water tight front bezels so they will not cloud up if rained on. Would prefer red needle, black face and white numbers with back lighting similar to the factory tach and speedo. Electronic oil pressure would be preferred to mechanical.
What are others using and any suggestions for high quality units that fit these desires? Where is the best place to install the oil pressure sending unit?
