bluewoo
Do either of these Spyders have any signs of spillage near the fillers?? :dontknow:
I can't help but notice that even for a 'new engine', the oil both your pics show is looking awfully clean for oil that's been thru the engine - even if only for a few hundred miles or so??Which makes one wonder, did whoever did the assy on either/both of those machines just get a bit sloppy when they were throwing the oil in?? :shocked:
Even a little 'fresh oil spillage' will go a loooong way; and given all the little nooks & crevices & trays where a small puddle could be trapped/contained underneath the tupperware on a Spyder, they could easily drip like that for MONTHS afterwards?! :gaah:
Possibly even longer if they were overfilled too!![]()
Mine did, and I saw and oil rainbow when I washed it but no drops of oil. Then I saw two drops in the fall, so without looking under it I washed again with some s100 and put it away for winter. Spring there was two drops still on the spyder and not on ground, one was on exhaust and other was straight across on left side of engine. The plastic cover was holding
Thanks for all the input everybody!
