Captainmal
Called the dealer that I just bought the 2022 Ryker Sport from. Put near 500 miles on it and it has been leaking oil on the garage floor for the three weeks I have owned it. No leaks sitting. Just getting wet while operating it. Dealer said they serviced it before i picked it up. Stupid me for not checking and then checking it wrong.
Cold the oil level was below the full mark. Maybe just above the middle between "full" and "add". Today I did the correct reading by riding, getting it hot, letting it idle and then do a fast shut off and check. Way too high.
Called the dealer's service. Asked if it was reasonable to stick a tube down the filler and suck oil out. OK on that and if still leaking to bring it to them. After trial and error, sucking 100 cc out each time. It ended up correct while hot with 270cc sucked out. That's about a 9 oz overfill. Watching it now with paper under the bike after a clean and then long ride. Dealer says there is no place for overfilled oil to vent out. So why the leak?
There were no leaks around either drain plugs. Saw nothing under the sump but did see oil wet down the side of the engine on the filler tube side. That then dripped off the front of the skid plate and frame. At no time did I notice a drop in the oil level when I checked cold but wrong. Do not think it was all that much oil leaking as a little oil can sure make a big mess.
Any clue where it might have been leaking from or what can leak if overfilled?
		 ) vent tube that used to reduce blow-by pressure build up under the rocker cover on these types of engines - it effectively takes any fumes that get past the valve guides or piston rings & end up being vented into the valve area under the rocker cover, & sucks/pumps them into the air intake duct after the air filter where any fumes can be sucked into the cylinders and burnt... so when too much oil in the engine creates excessive 'wet fumes' in any of the areas not actually inside the cylinders, all of those ultimately leak out anywhere they can or they can get pushed into the air duct... and once there, if the accumulation of wet oily 'fumes' gets bad enough & they re-condense into liquid, that liquid can end up filling the filtered side of the air filter box & either leaking out of the box itself (you hope!) or being sucked/pumped into the compression side of the cylinders/combustion chambers! :shocked: But since that sort of liquid charge CANNOT be compressed, you REALLY don't want that to happen cos the result is NOT GOOD!! :yikes:
