BajaRon
Well-known member
Am I correct in asuming you just rap the plug bolt with a hammer before inserting the driver?
Also what do you think about going after it with a 1/2" impact wrench?
What does BRP recommend for a torque setting? I'm curious as to why they are so tight.
Pretty much, yes. I used a short 3/8" extension to get some distance and have something solid to hit. I rapped it a few good smacks. Start out with less energy to get a feel for it. You can always hit it harder if needed. Make sure the tool is inserted all the way into the plug and keep it at a right angle to the plug. I would not recommend an impact wrench. Though I have not tried one. It's impossible to get a feel for what is happening with any power driven tool.
I have no idea what the torque specs are on the drain plugs. I don't think a torque wrench is used, in most cases. It's more a matter of; 'If tight is good. Tighter is better' approach. They just crank it down as tight as they are able and call it good. When all you need to do is just snug the drain plug a bit after contact with the washer is made. It will still get somewhat tighter through the heat cycles. But it will be much more manageable when you go to remove it the next time.
