bob edward
is there a torque setting on oil filter caps.
ray:
20 Nm (12 lb ft).
My bad, 11 Nm for filter caps and 20 Nm for the drain.:hun: 11 N-m (97 lbf-in) is what the filter caps use. The drain plugs are 20 N-m (15 lbf-ft).
The only time I've ever broke a bolt is when I used a torque wrench. nojoke
I do use them on things like head bolts but other than that I go by feel. I would not use a torque wrench on oil filter cap bolts, these have an o-ring so just get it tight by hand. IMHO
Question:
Who in here has those nice drainplugs that you can actually put a wrench on with worry of stripping them out?
(Within reason; of course!)
Question:
Wow.
I never thought I'd ever say this, but I believe you are totally wrong on this.
I see.
Your board so I guess you're right.
