OIL BURNING
Claimbo
I just had the oil changed on my 2016 res. I noticed a puddle in my garage and a strong oder of oil when I ride it. Sitting at an idle I can see oil burning off. The dealer said its oil caught at the bottom of the pan and it would go away. I have a few hundred miles on it but its still there. The oil seems to be filled. What do you think it is?
should be no puddles in the garage..Check your drain plugs that they are tight and not missing the washer too. I would take it back and have them check it since the oil was just changed.
Had similar issue
I ryde the F3...seems the washer for the filter kit is not designed to fit the Dimple plugs that I use. So my oil changing dude went to a crush washer. Problem solved...There should never ever be oil puddle or drip (in my case)...let us know what you find. Have a great weekend. :thumbup:
:agree: Check it over for leaks at the drain plug. :thumbup:
But if the dealership did a messy job of changing the oil: it might be worth insisting that they clean up the mess that they left in the pans. nojoke
All of the above
:agree: as well as if the dealer did the oil change it should never have left the shop with spill over in the lower pans/ panels. It should have all been cleaned up and saying that it will burn off, dry or evaporate :wrong:....
