Oil Addatives
Here in the UK we have a readily available product called ZX1. This is a chemical mixture which reduces friction by coating ( according to the makers ) only metal surfaces, which is added to the oil which is only supposed to be a carrier for it. I have used it in car and bikes for some years without any problems. I must be honest and say it works. It made my old Yam XS1100 much easier to start and the gearbox was a treat to use.
Now I know from this site that the Guvner ( Lamonster ) had a problem with Rotella and would love to know if anyone has used similar stuff in Spydie or not.
Any opinions for or against most appreciated.
welcome.welcome
:chat:
IMHO your Spyder stars easily and shifts smoothly, so why take a chance. Your Yamaha has a wet clutch so it should be ok. What good things will it do for your Spyder versus what bad things might it do. :dontknow: This is a proven engine in a low to moderate state of tune. It should last for a loooong time without extra additives. Just curious. Is the Spyder classified as a motorcycle in the UK? If so do you have a tiered licensing system?
Ryde Safe and Enjoy:thumbup:
sabunim5
my opinion
I wouldn't put any additives in a new bike with low miles because it typically doesn't go with the manufacture recommendations early on. If you keep oil changed regularly you really shouldn't need all this stuff anyways until you get to the high miles.
Sabunim5 Hi,
In the UK we can ride bikes with restrictions on age and engine size until you pass the tests, then its all go. Spyder on car or bike licence. Thats roughly it. No helmet required on the Spyder, but I choose to look after my head, well mostly anyway, unless I fancy a pop down the shops and show a big smile to all the locals.
:2thumbs:
