ataDude
Mod Maniac
A few mods...<lights, fuses, Hyper-Lites, Grip Puppies, throttle lock, RAM mts>
Accessory wiring:
To ensure that I didn't make the computer nannies mad, I ran an entirely new set of circuits (front to back) from the battery, through a relay, to a 30-amp Blue Sea fuse block mounted in the front compartment. The relay is activated by fuse three in the Spyder's standard front fuse block... therefore, all of my new circuits are on only when the ignition is on. An advantage to using fuse #3 is a built-in 15 second delay after the ignition is switched off.
As with all of these mods, I had the parts already "in stock" from other past bike projects. The Blue Sea box accommodates six fused circuits and six ground points. I'm only using three at this point... the Corbin heated seat will make four. All handlebar stuff (V1, GPS, etc) are low amperage and running on one circuit.
All wiring is run through plastic wiring looms available almost everywhere. I buy the looms from JC Whitney in boxes containing 100' each. :
Update: If I were to do this again, I'd mount the Blue Sea box not IN the front box but immediately behind it. Reason - if the luggage "box" needs to be removed, the "though-the-firewall" wiring complicates matters tremendously.
Accessory wiring:
