noise
webby1969
ringing noise sitting still after it shut off,hour later still ringing.turn key on and hear the fuel pump come on and after that the ringing goes away.turn it back to off and ringing comes back,,any thoughts? 2013 rt:mad:
You may have missed it the first time you read the owners manual but that is normal. The throttle bodies are held shut for 40 minutes after turning off the key. Maybe time to have a refresher read of the manual.
not everyone reads all posts in all sections and im trying to get some knowledge on my bike.sorry if I sound frustrated but I am
I must of cause after the noise I went to my owners man and didn't see it.will go again in the am.thanks for your time
just wondering cause last yr I heard it right before my relay went on my parking brake..that was 800 fix lucky it was covererd.after hearing it again I thought it might b realated and before calling my dealer I thought I would ask the other spider ryders....thanks for your time
Throttle body....
the length of time that sound continues will vary. Manual says 40min but mine will vary depending on how hard I road and how wet I put her up...let it run its course...this must be the post before you start shouting...:roflblack: really hurts my pupils....
The following was posted in your other thread.
"Fellow member told me to look on page 55 right hand column of owners manual under the words ALL MODELS****THIS VEHICLE IS EQUIPPED WITH AN ELECTRONIC THROTTLE CONTROL(ETC) EACH TIME THE IGNITION SWITCH IS TURNED OFF, THE ETC MOTOR STAYS ENERGIZED FOR 40 MINUTES. THE ETC MOTOR WILL EMIT A HIGH FREQUENCY SOUND DURING THIS PERIOD OF TIME THAT CAN BE HEARD IN A QUIET ENVIRONMENT. THIS IS A NORMAL CHARACTERISTIC OF THE VEHICLE. "
