NMN Riser end caps
rleathen
I just installed the NMN 3 inch risers (I already had the BRP 1 inch riser installed). One very quick question for those who have the risers installed. I also ordered the billet end caps that go over the heads of the chrome handle bar bolts and the end caps to go in the hole left where the original handlebar was cut. How do you install these caps ?? Do you epoxy or RTV them in place ???
Thanks in advance.
If I remember right, all you need to do is put the rubber o-rings on the caps and push them on. If you want to you could put a little silicone on each one. "No" contact cement or super glue
I had the same question and called NMN. They said to install the small o rings and slide them on. I thought the O ring went between the new bar and the riser so I will have to remove them tonight and fix it. LOL
One more set to install tonight then its off to test em out.
I used some black weather strip silicone and also on small one,s didnt want to stay flush tight so used silicone and painters taped them flush tight overnight.. on over a year now and still there
