This past month and a half have been a terrible spring riding season. First, I replaced the throttle body that has been acting up since I bought the bike. It started right up before putting it all back together. While I was at it, with the air box removed, decided to change plugs and wires. All went well, put it back together, ran it down the street. Turning the corner it started running on one cylinder. Turned out to be bad coil pack. Replaced it and ran great until you turned it off and tried to restart it. Just cranked, no spark. Error code P0335, crank position sensor. Replaced that, put it all back together and my fuel and temp gauges where messed up. The fuel gauge pinned itself past full, and the temp gauge read normal operating temp when off. It quickly showed the engine overheating, but the warning light did not come on, didn't go into limp mode. Disconnected the two gauges. Resulting bar graphs work fine. The analogy I use is that of a cancer patient.
After being operated on, other problems just keep on coming on.
