:thumbup: Nice list & sounds great now:nopic: Or 10?There is no dedicated accessory bus on the ST.
I have n 2013 STS and added a aftermarket fuse block under the panel
that houses the Switches for the parking brake, heated grips and fog lights.
You can run dedicated power and ground directly from the battery to the fuse block.
I added a relay to switch the fuse block. From the fuse block I run my GPS, Driving Lights,
DIY heated grips, USB Ports (3) and a Powerlet outlet for my heated gear. Also have
a garage dor opener located near the fuse block. Lots of space below the panel.
Cheers, David C.
:thumbup: Thx & I'm looking forward to the pics, I'm sure some will ask for a wiring diagram & fuse size too. Hope we can meet at Spyderfest :yes::yes:Right now the bike is a mess as I’m installing farkles, Saddle bags, Trailer hitch, Rear bag lights(DIY), Bumpskid
and updating the electricals. I will post pictures in a few days.
I like DIY and am constrained by a small budget so I built my Fuse box with this setup.
http://www.ebay.com/itm/8-Way-Circu...h-GND-DC32V-/361867751933?hash=item5440ffb1fd
Bolted a relay in the upper left corner to make the fuse block switched. Power and ground are direct from the battery.
I tied the relay signal to switched power from the unused air pump connector. Concept proven on my previous VStrom.
You may also consider - http://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/top-open-wired.jpg
Or the FZ1 - http://www.fuzeblocks.com/ (My choice for the next project.)
Driving lights are from CREE – no problems with them being waterproof. Mounted on the lower A frames.
http://www.ebay.com/itm/2-x-CREE-Wa...ash=item3ad19afff1:g:bxYAAOSwB09YH-fT&vxp=mtr
Powerlet socket for my heated gear.
http://www.ebay.com/itm/German-DIN-...-Hella-Plug-/301528740043?hash=item46348370cb
Marine Switches for Driving lights and Garage door opener. Waterproof and an exact fit to the
Spyder switch cutouts.
Momentary for the garage door opener. Fits in the slot for the suspension air pump (2[SUP]nd[/SUP] from the right).
http://www.ebay.com/sch/sis.html?_n...id=221876213183&&_trksid=p2057872.m2749.l2658
SPDT for the driving lights. I’m working with adding a jumper for this switch to plug into to the stock Spyder harness.
Right now I have direct wiring to the driving lights. Works great. Although all you really need is an SpSt ON-OFF switch.
http://www.ebay.com/itm/Waterproof-...d-LED-Light-/322343377148?hash=item4b0d2998fc
USB Charger port. I cut a hole between the Heated grip socket and the Garage door open for this socket.
http://www.ebay.com/itm/Car-2-1A-Dual-Port-USB-Socket-Fuse-Cell-Phone-Charger-Audio-Input-for-Toyota-/262710447901?hash=item3d2ac34f1d
Cell Phone and GPS holder. This unit comes with a USB port, RAM Ball and Clamp. I built a Holder for the
RAM ball and the Powerlet socket from scrap Aluminum bar, spacers and bolts found on EBay.
http://www.ebay.com/itm/Motorcycle-MTB-Bicycle-Handlebar-Mount-Holder-For-Cell-Phone-HTC-W-USB-Charger-/301947921572?hash=item464d7fa4a4
Cheers, David C.
Wow, great information. I look forward for you progress,Right now the bike is a mess as I’m installing farkles, Saddle bags, Trailer hitch, Rear bag lights(DIY), Bumpskid
Cheers, David C.
The ST has only two plastic retainers that are very easily removed and that panel just pops off. It think that is a pretty good location, plus it minimizes excess wiring.Any concern that if a fuse blows you have to disassemble the tupperware to change it? I would think it makes more sense to put the fuseblock in the frunk near the factory fuseblocks. Easier to replace a blown fuse.
LED strips added behind the saddlebag reflectors.
Wired per the Custom Dynamics Givi Bag LED installation instructions.
Wondering how did you set the wires to the saddlebags? Is there a quick disconnect in place? And how is it functioning after 6 months?
I have found lights on eBay http://www.ebay.com/itm/2pcs-Motorc...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
That I will wire to the tail lights. On our '09 GS a 4 wire trailer connection was used. Yesterday while at Fry's I found a 6 connection DIN connection set. The trailer 4 wire was physically Too tight and so tough to disconnect under the bags, I hope the DIN connection is not at the other extreme.
Look forward to hearing your update.
TIA
Be careful attaching anything directly to the tail light and turn signal circuit.
I found changing the load + or - from the stock 10w bulbs on the rear turn signal lamps caused the dreaded HYPERFLASH on my ST.
I'm experimenting with custom rear turn signals at this time. Found CB172-US lights on Amazon that I hope solve the 10W issue. Will finish turn signal testing tonight.
