New ST Limited Stalling
Is it possible that the idle speed is set too low??? My Spyder ('13 STS SE5) has never stalled, mine idles at 1300 RPM. I hope you all resolve the problem!:thumbup:
I have a 2014 sts I bought used with 650 miles. It now has 750 Mikes and has stalled 5 times. 30 seconds after stopping sometimes it stalls bit will start back up. Quite dangerous!! Hope it works itself out.
Ours did that when it was brand new. It was a one year left over so it sat around a while. The dealer replaced the battery and its been fine ever since.
2015 ST Stalls at Idle sometimes
I have had my ST Limited for 11 days and it has stalled 3 times while sitting in 1st gear. :yikes: It has started back up with no issue, but I am just wondering if anyone else has had an issue and if I should be concerned. Unfortunately my dealer can't get me in for three weeks, :banghead: so the first service is being done by another shop so we can go to Cody for the May long weekend. Any information, advise etc. is much appreciated. :cheers: Thanks Lori
I bought a 2015 ST last week and the dealer handed me a copy of a notice from BRP that stalling at idle and stopped may occur during the break-in period. Should restart?:yikes: Well being fore warned I got a mile from the dealer at a stop light, yep it coughed and died. Hit the starter and it restarted just fine!:yes::yes: I thank the dealer for sharing what info they had and being warned i stayed in the right lane while getting out of town. Hasn't stalled again, great machine rides very smooth compared to my old 2008 GS. Happy Rider!:yes::yes:
Stalling, Mine too
Mine stalled once in the first 1.5 miles city stop and go traffic. Dealer had cautioned me that it might stall at idle and stopped during break-in. It did just the one time and a couple of other instances it felt like it was going to stall at Stop light, so slipped into Neutral and feathered the throttle a little for a few seconds. Fore warned is fore armed thanks to a sharing dealer, he showed me a TSB or notice from BRP and I was grateful for that. The fuel mapping is pretty lean so with a tight engine occasional stalling is to be expected. just ride it and it will cure itself!:D
2015 ST L SE5 stalled
I have a 2015 ST L SE5. Always use premium fuel.
It has 2500 kms on it. Stalled the first time today in first gear.
(I filled up before going home and had 30 kms on that tank)
Thought I pushed the kill switch as it just died. No.
Pulled over, couldn't get it out of 1st gear.
I had power as the screen was showing and radio worked.
Just wouldn't start. I rocked it trying to get it to go into gear. Didn't work.
After 5 - 10 minutes I managed to get it into N and start it.
Drove a few blocks. Shut off. Started again and went home a block.
This is the first time it died like that. Now I'm afraid it will do it on the highway.
Temp today was about 26 C. So not overly hot.
You can start it in 1st gear if your foot is on the brake. Check your battery connections. They will work loose if a star washer isn't on them. When all else fails pull the key out and wait 10 - 15 minutes.
