I have a new 2014 ST limited. Now has 1900 miles. I try to do all my own maintenance. So far just a oil and filter change. visual on belt alignment. No real problems other than squeaky front brakes. What should I be looking for as the miles rack up?
Also the belt makes a strange noise at certain speeds. Is there a fix other than a spring loaded idler?
I found the handling a little vague as you start to turn. Seems like it wants to lean a bit before turning. Like the roll center is high. I added a couple of turns to the front spring preload. Also I raised tire pressure in front 2 psi. This made it handle better. I'd like to see it track better. Larger sway bar?
