New seal boards great but...
2manycars
Is it my imagination or is there a lot of vibration transmitted from the boards. I never noticed it before and it is not a big issue but I wondered if there was a "fix." Perhaps a small rubber washer between the bolts and the driver peg. I can used to it, but I do notice it.
Overall however, the boards look great and add a lot of places to stretch the leg on longer rides. They should also prevent "riding the brake."
Yep, I noticed more vibration as well, probably because the vibration is now going through the entire floorboard instead of just the pegs. I did as you say and put rubber washers between the peg and the board - I also purchased longer bolts and put the peg weights back on. Be sure to install them with lock nuts and blue loctite. I still feel some vibration, but it's not bad. I would definitely keep the Seal Floorboards with vibration over the stock pegs any day! :yes:
I have Seal's PUP boards on our RT Limited and they are vibration free. I had very little vibration in my original foots pegs before the upgrade. This may have been due to Jim's Belt Tensioner I added prior to the floor boards.
I left the weights
I left the weights on originally. I have to try some rubber washers and longer bolts. Of course then I probably need to raise the brake pedal some. As you said, the boards are a large improvement over the stock pegs regardless.
