New Performance Air Filter System
If you add more air [hi flow air filter] all you get is more noise.To gain more H/P You would have to add more fuel. Same thing with exhaust pipes. Noise dosn't = H/P. Just findings from my old drag race days.
65 Olds 442
68 charger 440
Just got done designing this setup for the Spyder. I can't stand the stock air box. Once you take it out once or twice, you will never want to do it again! Its a cumbersome piece of production plastic! This setup mounts a round style K&N air filter on top of your throttle body for a super clean installation that is sealed tight as a drum and won't leak dirt past the filter.
http://www.kewlmetalstore.com/product_info.php?cPath=5_43&products_id=401
Mad Matt
Wow! That is a nice clean efficient design. Got to know what the wife thinks about the decibels.
65 Olds 442
68 charger 440
The ECM very well may be able to adjust fuel mixture to take care of this--- at least to some degree. I know they say to let the Spyder run for 15 minutes after installing the Hindle - to let the ECM realize the extra airflow and adjust accordingly.
When I added my race intake I increased my fuel pressure at the same time (from 50 psi to 62 psi). I believe having a Juice Box could also allow for more fuel too.
15 min exhaust run
I think the reason to run the bike for 15 min. and let it cool down after installing the Hindle is for lack better words, to season it. This should be done to all exhausts.[especitally chrome] Most times it's done by accident, i.e, Moving the bike from one spot to another spot. Maybe this would explain why some stock exhausts discolored ? [not run 15min. then cooled]
Just my humble opinion.
before it seasoned.
Here's my thoughts, I like the Evoluzione Race set up better. 1) it allows for more air to be pulled in based on the design. I think the Race air will better pull colder air from the upper vents on the panels. 2) The race air takes the pcv line and distributes the oil mist evenly back into the cylinders where the K&N set up allows the oil to go back up onto the flat surface mount of the bottom plate and could be another leaky messy design like factory.
I guess we'll find out if what you say will happen when Mad Matt responds.
Would'nt you know. This comes out just after I bought an Evoluzione one. But I got such a great price from a member on here, I really cant complain. Plus its not really that loud over my exhaust. Just had to go up to 70 percent on the music.
Bulldogger,
I am going to go ahead and change the design to port the crankcase vent straight to the throttle body to ensure it does not get messy. As far as more colder air, I can't say for sure, but if you want to run oil wetted foam, then use Evoluzione, if you prefer the K&N filters, here you go. I will post a pic of the new design with the updated porting as soon as it comes off the machine.
Matt
Matt
Bulldogger,
Matt
Matt
Moving the oil port to the throttle body is a good idea. K&N also uses oil on their media cotton gauze filter. I don't think there would be much difference there. Other then that, it looks like a real nice set-up, and should be quieter then Evoluzione because of the non-open top, that will minimize the sucking noise:thumbup:
Always nice to have options. I originally wasn't thrilled with oiling--- but with the spray-on oils they have now it's a piece of cake to do.
For sure need to vent that breather right into the intake.
I might have leaned towards this new setup had both been available at the time.
No cold air intake on the stock Spyder. Air is pulled from under the bodywork.
Thank you for the response NancysToy, with that in mind I would lean towards the evo race. I have run true flow for years in my diesels and love the reticulated foam filters. I wonder if the evo race is also the same? The site states "dual density high-filtration foam filter". Second question would be can the stock ecu add enough fuel for the air filter and exhaust? Most obd2 cars I have tuned the stock ecu could do +or- 10%, not sure about the spyder.
Evo race foam is a very similar set-up to dirt bike applications, high quality flow but still catches dirt. As far as a stock ecu, I don't know, but for $230 on ebay you can get a Juice box which is what I use. It allows you to adjust fueling. My plug readings are perfect using the combo, I have Evo racefilter, JB Box and Hindle pipe and all is good in the world:2thumbs:
:agree:
I would get a JB with the setup.
I have the fuel pressure mod - but the JB was not out at that time.,
