NEW OWNER QUESTIONS
poordom
Good evening all,
I am picking up a 2009 Spyder, tomorrow.
I will obviously have a lot of questions over the next couple of weeks, I hope you will bare with me.
I have NEVER driven one, today while speaking with the mechanic at the shop, he warned me, that I should ALWAYS make sure the bike was in neutral before turning it off, otherwise it's a bitch to start if you haven't.
Now knowing what I am like, I will probably turn it off while in gear, any suggestions or recommendations in relationship to this issue.
Thanks Guys
Dom
If you press the brake while starting, the SE will start and shift to neutral by itself. It will not be a bear unless you have a brake switch problem or some other related problem (like not pressing the brake hard enough). This procedure is in your manual, along with a way to manually shift it back to neutral if it gets stuck in gear.
