New Member with Important Question
Hey All,
As I mentioned in my original post, we have ridden the RT a couple times, and that is the trike we are considering. However, today in was looking at the Can Am website, and I started looking at the F3 Touring version with the trunk and everything. I wonder if that bike would sit more like my motorcycle that I'm used to? It looks to be more feet forward. I really like the feet forward style. Just wondering.
Robmorg,
Since you have experienced the Yamaha product, and specifically the Venture, which is the same bike as my Tour Deluxe, you certainly understand my issue. I think we need to look strongly at moving to a trike, and in particular the Spyder, but leaving such an awesome, quality built product like the Venture/Tour Deluxe kinda makes me look close at what will be replacing it. The V4 motor that is in the Venture/Tour Deluxe is one the all time most reliable motorcycle power plants ever built.
I truly believe, as you stated, there is no trike that is more fun to ride than the CanAm.
Lenny,
I know EXACTLY what you are saying, and I agree with every word. But believe me when I say that once I had about 500 miles on the RT, I have never looked back. Switching to the RT when I did, was one of my finer decisions, if I do say so myself. ;) My oldest son now owns and loves the big Yamaha. :thumbup:
As for the F3 Touring, your comfort level on that model will depend a lot upon how you are built. Doesn't work for me, but you should try a test ride on it and see what you and your wife think. An awful lot of folks do like the F3.
Hey All,
If you were a cruiser rider the F3 is probably more your style. The foot pegs are adjustable and feet forward.
Don't Beat Yourself UP....
Lenny--
Welcome to the forum. I spent way too much time thinking about buying the 2015 RTL that I bought. At 68 it is my first bike. I do not regret it one bit.
I would recommend that you get some performance items (in this order)
1) Laser alignment preferably Squared Away at Spyderfest in Springfield, Mo. They are out of Vegas so that might make trip worthwhile. Get tires balanced also.
2) Baja Ron torsion bars
3) Baja Ron shock adjusters
The combination of these will make the ride better and smoother. Your tires will last longer. I had to replace all there of mine within 9,000 miles.
Good Luck and Be Safe. :spyder2:
BTW, I am down here in Dallas.
Bob Webb
I own two Yamaha sport bikes and right now have a problem with my 2014 still low mile model. I put more miles our RT Spyder and have had no issues with it.
Buy the RT if you want to move to three wheels. There are no better options.
Av8er, From all that I have read and people that I have spoken with it is not so much as more reliable as it is less of a chance for an issue. First the auto by its nature has more mechanical parts and that alone means less problems to me. Because it has a centrifugal clutch the engine needs higher RPM so that the clutch engages, on the manual when you are off the clutch it is engaged. That's true for the SE5 but not for the SE6 (with 1330 engine). The SE6 has a real clutch that is hydraulically operated, and RPM is not a concern like it was on the SE5. Just ignore the clutch and watch for engine lugging, as you would for any stick-shift vehicle.
When I was in the MFS course we were taught to feather the clutch for control which you cannot do with a semi. Sort of true and sort of not. It's just quite a bit different, yet beautifully adequate. I'll try to describe some of it here: on take-off, you can feel the SE6 clutch engaging and then very quickly "locking up". You couldn't do it any more smoothly with a manual. Now, on deceleration is where more difference is noticed: you get LOTS of engine braking with either the SE5 or SE6, and you cannot feather the clutch manually, of course. However, you CAN feather the deceleration by using the throttle, and this comes naturally and very quickly... you very soon learn perfect control of your deceleration rate. Also, something not mentioned yet is the option of manual downshift or automatic downshift, which gives even further range of control. However, it IS true that the clutch can never be disengaged at speed, which forces you to maintain momentum rate with the throttle. But this is a very short learning curve (with a throttle that covers its full operating range in only 1/4 turn). Finally, the clutch only disengages right before coming to a complete stop, at just the right time.
The auto has 2 oil filters while the manual has one. I am very happy with my manual to me it adds to the experience "I" want in ryding.
Is the auto bad? I am sure it is not. Do more people have more problems with them? I don't know. Do I see more of a potential for a problem? I do. Will that problem be more expensive to fix? I am sure it will. And I'm sure you're right about that! Another good reason to stay under full warranty... I have 5 years worth on mine. :sour:
Will other ryders here comment on this? I hope so as I do not have all the answers. Neither do I, but together I think we've covered a lot. :doorag:
Bottom line- Test drive both, talk to people, read everything you can find, then do what is best for you. And get out and ryde and have fun.
Safe ryding
:riding:
Jeff
See blue comments embedded above.
Hey All,
It'll put you in a more cruiser-like seating position...
....But the rear passenger seat area is not nearly as comfortable for longer rides. Make sure that "The Boss" will still be happy! nojoke
