Any AFR gauge system I've ever come across - and granted, I haven't seen them all - the wide band sensor goes into a separate bung that you need to install. It's sometimes a different size. You still need to keep the original O2 sensor and circuitry intact because the standard sensor is a lambda sensor and can't drive an AFR gauge. Plus the installed standard sensor is still required to control the AFR in the closed loop portion of the fuel operating map. Without it, it'll be throwing codes. So, Rev, if you're not familiar with the fundamental operation of closed loop and open loop ops of an electronic file injection system, and how the O2 sensor controls the AFR, you'll just get yourself all balled up playing with maps. You'll be trying to adjust AFR and the system will be adjusting it back to where it was. Then you'll start fighting codes. It's just another reason why I think an ECU flash is the better way to go than the Power Commander now that a flash is available.
But, the Autotune system from Dynojet is made to work with the PCV. Perhaps that would be a better fit for you.
On the other hand, if you have a different kind of gauge system that works with the standard sensor, then by all means, train us up.
