SpyderDog65
There's already places on the kewlmetal risers to mount stuff like gps and other stuff I love mine the options for bar position are what makes the kewlmetal risers the better choice
Kewlmetal risers work for me 6', tall upper. These probably have the most adjustment of any out their.
To each his own. I prefer that look. I have the ESI 4" (black).
http://www.esicycleproducts.com/spyder risers.pdf
Another question... What is this locking thing a few of you talk about? My steering wheel still moves around no problem with the power off and key out :dontknow:
Some of these options do not allow the steering to be locked. With ESI's for example, you can still lock the steering.
You do know the steering can be locked by turning the bars completely left or right and then turning the key CCW?
No I did not know that. Never even thought of it. Was this the same as the RT? We tow a lot (Spyder in trailer) and never had an issue (Washington to California and back) with the RT steering moving. Now we have had the entire bike walk sideways...
Our Spyders are mostly parked at our business or in it's garage stall most of it's parked life. So I never even thought about the need to lock...
I think I will just go with the HELI bars/GPS-12v plug in and wiring. Seems to be the best overall choice as I cannot bring myself to cut the bars on a brand new bike...
Now where do I find a discount code?hyea::thumbup:
Went with ESI and had the dealer cut the bars...it's really not a big deal and they make a big difference. If you want your bars back, you can get them from the dealer relatively cheaply.
I have found my ESI handlebars to be quite functional. If you look at what else is available, the lines of the ESI handlebars match the bike far better...they look like part of the bike whereas some of the other options really stick out like a sore thumb.
You should see a bike or two with each mod before making a choice. If I had to do it all over again, I'd still go with the ESI handlebars...but hey, there's something for everyone!
1. Mounting the risers 1" farther out will make the cable length a real stretch. I doubt you can pull it off, but anything is possible.Ok.. So do the bars press into the factory position or how?
Additionally... If I left one inch on each original bar more than the instructions call for to allow for mounting points for aftermarket mounts (Thinking GPS -Ipod-etc)...
- Will I be able to mount the risers on the outer edge of these longer bars so I can mount to the inside these aftermarket thoughts?
- When angling the risers towards the driver does this cause the angle of the grips to turn in more or do they stay the same? (My issue is I need just a little more angle up and out from previous injuries in life to be comfortable on long drives)
1. Not sure what you mean by "Do the bars press into the factory position?" The forward position and angle can remain as stock, but the bars would be 4" higher and slightly back due to the steering shaft angle. The bars can be moved further toward the front or rear, but that would change the hand angle somewhat from stock, moving the end of the grip somewhat further up or down. (This would be easier to explain in person, with a broomstick demo.Man you guys are making this tough hahahahaha...
Ok still two questions...
Additionally it seems I only have one option and that is the SE5 4". With me needing black it now costs $280 before shipping, which is why I decided on the HELI's originally. That is just a huge cost for so little of an item. Remember, been dong this for a while off-road and Risers are a standard add on with every ride. I usually us Rox Risers... (Link) And their Anti Vibe ones are killer!
- Do the bars press into the factory position or?
- Can I still mount my ISCI Hand Brake with the ESI risers?
