NancysToy
Motorbike Professor
I would not replace either the spark plugs or the plug wires with non-resistor types. There are a couple of issues with that approach. First, the RFI emitted from either can adversely affect the CANBus sytsem, causing all sorts of possible problems. Second, damage to the coils, or even the ECM, could result. Third, the RS uses ionization current sensing knock control. A change of system resistance could trigger a response of the anti-knock system (or fail to trigger one), degrading performance or even causing engine damage. Modern engines should not be operated with non-resistor plugs or wires. Something changed on your machine, causing your sudden problems. You need to find the culprit and correct it, not create a new monster. JMHO
