daveinva
So I installed these over the weekend, love them, but I am having a problem: they're loose.
But NOT in the place the instructions suggested they'd be loose, i.e. where the ESI extensions meet the factory mirror bar, but instead where they meet the cowl.
I can't get the bolt with the stock bushing to tighten up enough to keep the mirrors from pivoting on that bolt (I believe there are three little "tabs" that are supposed to line up with three notches to sort of lock in, but neither of mine want to line up and lock in-- of if they do, it's still not enough to keep the mirrors from pivoting).
It's not a lot of travel-- maybe 3/4 of an inch at most-- but it's enough to shift the mirrors from a perfect view to a bad one.
Anyone know what the solution is? I tried an extra washer atop the bushing to no avail; I then instead put a washer *under* the bushing and that helped a little bit, but it still didn't solve it.
Loctite, maybe?
Loctite, maybe?
