Need help locating an audio cord
smurfette
GOS member (Girls On Spyders)
Good morning everybody!!!!
I know someone in my spyder family will know where I can get one. While cleaning out the garage, I somehow misplaced the coiled cord that goes from the helmet to the audio connection port.:banghead:. My Smurfette is a 2010 RT-A (with a few mods). I do have the factory CB system installed. If possible, I'll probably pick up a couple just in case i have another brain cramp:opps:. Also the helmet I had it on is a 3/4 helmet , if that helps. Help!!!:bowdown::pray:
Hang on there... The brand of headset installed in the helmet will dictate where you get the cord. Go back to the headset retailer or manufacturer.
She said she has the factory CB installed, so with that information, she can either get another cord from her dealer or J & M Corp. :)
Nope. :lecturef_smilie:
For instance, I have the factory CB installed and have a J&M headset in one helmet and an EdSets headset in my other. While they both plug into the headset jack on the RT, they are NOT interchangeable between headsets. I don't know if the BRP branded headset is compatible with either J&M or EdSets, but there are at least three possible cords that are different from each other. You must get the cord that matches the headset manufacturer.
