ornerydog7
2011 RTL / SE5 having issues. Idles roughly at start up then smoothes out for approximately 7 - 10 minutes before shutting off. Showing codes P2279 an P0106. Would like to hear from the group before taking to the dealer.
Yep, if you havent replaced to 2 hoses. They are way over due. I just did our 2011 RTS last week. They are the 2 red hoses in the pics. I used the napa lines.
And this is what my stock lines looked like from an 2011 RTS w/ 15k miles
Sent from my SAMSUNG-SM-G920A using Tapatalk
You might need a needle nose pliers to pull the old hose off. If it still wont budge use a knife to slice the side of the old hose at the fitting. Use the old hose as a pattern to get the exact length when you cut the new replacement to length. It's not as difficult as it seems.So, I have found that my front hose is definitely cracked wide open and the other one has sura e cracks. The back hose looks like it is easy to replace; however, the front one is a pain. Do you have to loosen the Bosh Controller to make it easier to replace the front hose or is there some other way. Do I have to remove the air box?
Where did you get that air filter assembly from? Do you have the brand and part number?
The hoses are on the left side. You can get to them without taking the air box off, but it is tight. How many miles on you bike? If it is time for spark plugs and wires, take off the air box. Change the air filter while you are there.
Get the plugs and wires from BajaRon.
so that is the left side when i am siting on the bike right ?
left is left and rght is right thank you .HEY i did not tell all of you the can am only has 5500 miles but its a 2011 and when i got it used it only had 3500 miles but will check it out THANKS ALOT EVERY ONEso that is the left side when i am siting on the bike right ?
