Need help identifying wire colors for wiring admorelighting top mount lights.
Quickdraw
Looking for some help.
I bought a set of admore lighting top mount lights for the Givi V58 top case which is going on the wife's 2022 Spyder RT.
I was hoping to use a harness that plugs into the stock CIC1 harnesses under the seat but the harness I bought, after wiring it to match the lights wiring diagram, no matter which directional I try, both the left and right flash. The harness may also have the brake and running light wire colors wrong too and well that could be causing this whole issue.
Does anyone know on the bikes CIC1 wiring harness, which color is for brakes, which is for running light, which is for left turn and which is for right? Ground is the only obvious one.
Thank you.
Thank you.
This is off a 23. Should be the same. Is this what you want?
I identified all of the connections with the help of your diagram. Odd that every connection on the Show Chrome PnP connector is correct but both blinkers flash. Admore also sent me the color sequence so between the both, I should be able to get it to work.
