Need Help Brake Light
corvette99c5
I just got my spyder and driving home i found that when i push on the brake light the left is off and the right one is on. Is this a bad bulb? the bulb regulary lights are fine but when i push the breaks the left one turns off.
thanks
The only way to tell is to pull the panel and check. It should light but it could be a bulb or it could be unpluged.
Mine burned out the right side tail light bulb the first time I rode it. I just put a 1157 bulb in I had works fine ever since.
If the tail light work until you push the brake and then the tail light goes off, IT HAS BAD GROUND on that light..
