Wmoater
I had my front sprocket cleaned really well for the recall inspection. I then removed my belt and cleaned it really well with dawn soap and applied conditioner. The reason was i was getting a really bad belt squeal. The squeal has gone away completely. For the last 2 days I have really noticed that my belt is now settled in the middle to outside of the rear sprocket. It’s definitely running a bit to far out. Over the Spyder's life I had 2 rear tires put on and when I took my belt off “three times total” no alignment has ever needed to be done. It's always run perfect just about 1-1.5 cards from the inside. I had my son over and I was surprised when the front wheels turned all the way to the right and put in reverse at a sharp turn and he backs up sort of fast the belt slides to the outside edge completely. I realize that it should move a bit but that’s too much, I think. When put in forward and driven down the road it goes back to being perfectly centered on the sprocket. When I installed the belt, I must have had something move just a bit. I was watching the video from Australia where the guy leaves the rear wheel engaged and adjusts the left and right Allen bolts. I believe if I am reading my Krickit the tension is correct. Do I simply loosen the 36mm axle bolt, on the right-side nut till it touches the pin and only adjust the right-side Allen to bring the belt “in” a touch. I shouldn’t have to touch the left side at all correct? I also read on here about tapping a wedge in before tightening the bolt. Can someone verify that I only turn the right Allen if tension is correct and what and where the wooden wedge goes, please. I do run the Lamonster tensioner and have no vibration at all.
