Need a replacement radio antenna.
I live in an area that does not get great reception as it is so i want to replace with something premium that will actually improve the reception. The wal mart seems about the same as stock just shorter? i have a 15 and no problems with the length of the stock one now, just that is sucks. my car which has no vertical antenna gets better reception.
as a side not how hard is it to get to and replace the front speakers on an RT?
Thanks for this video! :clap: :thumbup:
I think that this fellow just posted a video in here about the wrap that he put on his bike. It was probably within the last Month...
terrible video took to long heing and haing . get to the point I do not like long dragged out videos
Boy I tell you... Tough crowd!
You should be grateful someone did a video showing how to do it rather than complain about how well they did the video! :banghead:
The gall of some people to complain of something they got for free that can help you. :lecturef_smilie:
Maybe you should do your own video and lets see how well you do!
Bob
MAYBE
If you have a " DEEP " 7mm socket...slide it down the antennae, put vise grips on it and remove it.....clean the threads of the excessive " thread locker ", then put only one drop at the very top of the threads and screw it back in......this may improve your reception......On the speaker thing, I re-placed mine with JBL 2-ohm model's, and actually got 5 1/4 in. into the rear to re-place the smaller OEM's........I paid about $ 125.00 for all four....Bob finless did a video on the front ones ( very nice Bob ) and " beadaholic "posted some for the rear........I would honestly say My stereo can play 50% louder with 100 % better quality than the OEM speakers...........Mike :thumbup:
Replacement antenae 2013 spyder ST limited
My was broken at a hotel while traveling. Bought a new one but was able to fix the old one. Unscrew the brass end from the base. Drill out the fiberglass piece and then very carefully cut the end off the broken antenna and replace back in the brass piece with epoxy. Works great.:yes::yes:
Sounds good but what did you do about the wire in the antennae. If you cut off the end/drill out the fiberglass don't you disconnect wiring for the antennae?
Antenna install
I installed the same antenna from Walmart as the video demo shows. It took me maybe 15 minutes. Once the threaded pieces were together and installed, I pushed the boot over the end of the antenna (no drilling or cutting needed-it is rubber) and left just enough room to screw the antenna in place. Then it was pushing the boot the rest of the way down and inserting in place. A small flathead screwdriver, used carefully, helped get it in place. Wish my other projects went so smooth. It had great reception in the garage. On the road?? Time will tell.
