If all of the above fails...change the wife..:roflblack::roflblack: I'm sure she will come around. Small trips to places she wants to go then slowly further out..
Do you have a photo of your seat and armrests? The Corbin armrests look good to me and look like they will give the passenger a more secure feel when riding.
I've seen enough good comments on Ron's sway bar and I'll order one Monday.
My plan is exactly like yours get some slow easy riding time in and get the fear of the lateral force out of her mind. I hope to get her to drive the Spyder at some point and that was the whole point behind getting the SE5 even though I like the SE5 transmission now a whole lot.
Don't be surprised if I show up at SpyderFest on my Goldwing... I may not have enough time to win her over before then.
John
I agree with all of the above, but specifically the last line. the big mistake was the improper set-up! IMHOIt sounds a bit like you got off to a bad start with the wrong air pressures and the semi jostling.
I ran into the same problem when I worked with akspyderlady. She was not going to ride on a motercycle--period!
I talked her into an introductory ride and we went around the blocks in my neighborhood. I never got out of first gear. Made sure the stops were smooth, the turns included no g's, and the starts were also smooth.
After about a half hour, she was willing to go further. I live on a road that skirts the neighborhood. Six miles or so of twisty, turning road, with some 15 mph curves. Once again, made sure I did not exceed speed limits, and followed all the stuff in the paragraph above. A couple times through the loop in both directions, and her confidence was up.
Bravery test time, enter the Glen Highway (65 mph-two lanes each way) for the 5 miles back to the next turnoff ramp. Other than the acceleration to get up to speed on the ramp, all went well.
After that, it was no problem to get her to ride with me. She put 5000 seat miles on that first summer. At the end of the season I started learning her how to drive the Spyder. She put a couple hundred driving miles on it--using the same techniques I used above.
The 2012 season began with her puttiing almost 1000 miles on my :spyder2: driving it. In July, I bought her a new 2011 for her very own. She put 5000 miles on it before we parked it for the season at the end of September.
Give it another try with your wife, but make sure the :ani29: is set up and driving the way it should first.
In the mean time I've sorted out the tire pressure and went for a 200 mile ride yesterday solo. Last night she says "since you rode the Spyder all day today can we take the Goldwing tomorrow?" clue #3
I don't know what to do now...
John
????? The RT has adjustable passenger footboards......But we have not solved the passenger adjustable pegs ......
Hi JT,
Lots of good advice from others here, for sure. Do you have a communication system for you and wife to keep in touch with one another?
One thing that made some of the uneasiness pass for my wife Sandy when we first got our 2010 RTS was when we got our comm system installed and could talk easily. Prior to that, us yelling to each other just added to her sense of not being fully relaxed.
Some nice weather days with short rides to places that interest her, and repeated application of such (Woody's point) is what I'd prescribe too.
Good luck, Bill
That was the first thing I did before we went out on the first ride... ended up all the way up.
My googlefu seems to be having problems this morning and I can't find BajaRon's web site...
John
John
She did comment that she could not see the speedometer or the the mirrors or the curves coming up... must be why I didn't get any governor taps on the helmet. I have to assume that being a bit higher up and being farther back from the center of motion would give the passenger a lot more movement. I'll just back off and go slow till she warms up to it and let her drive on some back roads a bit..
John
One word of caution. Not everyone likes armrests. If you don't have them on the 'Wing, your wife may not want them on the RT. My wife would not tolerate armrests on either. She made that very clear. Don't just assume that she'll like them and feel more secure. I would personally save armrests for the last step in a long process. If you finally get to that point, make sure she thinks it's a great idea.
When I first sat on the back seat i was sure it was going to be too small, compared to the GW seat. And the RT Limited custom seat is even an inch or so shorter, so I worried about it again. At first she didn't like the edges on the side of the seat, but now does, and has not complained about the length, but I'm still hesitant to get a driver backrest that might take up more space. She has driven some with me on the back, and I actually enjoy being a passenger--occasionally. We also went through the learning curve, no pun intended, with the corners. All of the previous comments are applicable.
But my point in commenting is actually full disclosure to her--let her read all these comments to see that others have also struggled with this, and overcome. Maybe that will give her hope and courage to stick it out.
And if you can get her up to, say, 250 miles, you can stop at our house for a break.
Bert
