jaherbst
I like your approach but you might be pushing the envelope here. You have a lot of weight very high with single axle. I am concerned what the trailer, wheels and tires are rated for. With weight that high you are putting a tremendous stress on the sidewalls of the tires and the bearings. If they were made in China which I suspect they were I would change them now.
For just a few dollars more, less than you spent for the lumber, you could have bought a larger trailer that the Spyder would fit in and not have all the worries. Weight rating would be higher for the trailer and the tires would probably be D rated.
For what you spent on the trailer and the materials you could have bought at least a 6-7 foot wide trailer with higher load ratings and the load would be much lower. To me this just does not make since. I think you are setting yourself up for a real disaster.
I have towed trailers of all sorts all over the US and Canada in excess of 200,000 miles both for myself and commercial use and am speaking from a vast amount of personal experience. I do admire your willingness to try to solve the problem but----
Jack
