My ST has Two OBD ports - anyone know the difference between them?
Marek
My Spyder ST has two OBD ports 6-pins. One is plugged into the hole, the other is a cap. Anyone know what the difference is between them?
I can't speak to the ST but 1330cc Spyder has two diagnostic link connectors -- DLC1 for BUDS and DLC2 for Rotax. DLC1 is a Deutsch DT6 with five pins populated.
While the Spyder uses CANBUS messaging extensively, it's use of OBD is limited to non-standard PIDs proprietary to Bosch. So while you can see the DLC1 messages with a CANBUS sniffer, decoding them requires BUDS or the patience to link cause to effect.
My 2013 Spyder ST the one plugged in the hole is the BUDS connector for hooking up to the software on the computer, no clue what the other is for
