BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
Hi All. Just gotta add my 2 cents worth here.
The way I see it is if the rear of the bike is supported in such a way that the rear suspension is carrying the load, i.e. supported under the shock bolt or the swingarm, the tire can/will be off the ground but the swing arm will have the same angle, w.r.t the frame, resulting in the same belt tension as when the tire is supporting the load, i.e. On the ground.
Thanks for bearing with me. "bearing"![]()
If I understand you to mean " there is No difference in belt tension on the ground or off the ground " I dis-agree, I and others have measured it on & off and the tension is different . .... try it yourself .... Mike :thumbup:
