As I mentioned in my post, the fork is backwards. Call it what you like but it is not correct. Pretty typical department store build. The bars and stem are positioned correct...the fork assembly, including the wheel is 180 out, note the leading axle is aft and the V brakes are aft, even the cable route is jacked. To me this is backwards. Simple fix, loosen two bolts, maybe one, spin it and retighten. No big deal, see it all the time, and Dave will handle it however he sees fit. Maybe he plans to do circus tricks on account of the shorter wheelbase.
PK
