New Guy on the Block Here,
I haven't purchased a Spyder yet, but as soon as the new 2014 RT-S makes it to the showrooms, I will be buying one. However, in regards to the 2013 heat issue, does anyone know if radiant barrier would work? I've seen some very impressive demonstrations where radiant barrier was able to block all of the heat; keeping it to the one side. I'm sorry to hear of everyone who is having the issues, and I know there are many other bikes that have heat issues as well. I've had heat issues on previous bikes as well, but that was before I knew about radiant barrier. Just keep in mind that the barrier has to applied correctly to work correctly. You can't apply it to the heat source, because then you would get heat transfer due to conduction heat. However, I think that if you apply it to the underside of all panels (with a thin layer of insulation between the panels and barrier), this may very well greatly reduce the heat that is felt on the legs and seat. This is a fairly inexpensive modification, and for anyone who owns a $20K+ bike that is experiencing this issue, it is well worth the investment. I'm certain it will lower the temperature you feel. The only question is, how much will it lower it. I know if I experience this problem on my new Spyder, I'll definitely be giving it a try.
Just my two cents,
Texas
