ARCTIC
I was looking at the belt alignment on the rear sprocket and it was nearly rubbing on the internal flange. I loosened the rear axle nut and adjusted it so it was off of the flange on the rear drive wheel and it took probably a turn and a half on the muffler side adjuster screw. :yikes: So then decided to check to make sure it wasn't too close on the front and discovered that it's up against the flange on the front drive sprocket. Is my belt fawked? Is there something else that could cause this or another adjustment that I'm not considering like a spacer needs inserted to offset the rear pulley??? Not sure on this one. Thanks again for the help in advance!
Brian.
Brian.
