RayBJ
Well-known member
I wanted to add an LED DRL below the headlights and BRP sells a plug & play strip for $265. :roflblack:
https://can-am.brp.com/on-road/us/e...ights-accessories/lights/auxiliary-light.html
Soooo,
I went to amazon and found these for $22. a pair. https://www.amazon.com/gp/product/B087JFXP3B/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Easy install -
1 - remove the trim plate (2 screws)
2 - unplug the un-used connector from the back of the trim plate
3 - drill hole in center of the trim plate to pass LED wires through
4 - align LED strip on trim plate and drill mounting holes
5 - mount the LED strip to trim plate
6 - tap (I use posi-taps) into the wires of the unused connector (black to black, red to colored)
7 - test by starting engine (LEDs should be on with headlights)
8 - replace trim plate w/LED
Bonus: you have a spare you can use elsewhere!
Soooo,
Easy install -
