My can-am f3 keeps reading BAD KEY and I can't start it.
RichieRich007
I'm having a problem starting my can -am when I go to start it I put the key in and it reads BAD KEY so I watched some videos and I found it says maybe its the little round thingy that goes around the ignition where you insert the key. So I took that off and I play with it just a little then I decided to check the wiring then I noticed that whatever wire that connects to has been cut or came loose. I'm looking to see where does the wire connect to and is this the problem.
Some of the earlier Can Am's had problems with ignitions and it had to do with an antenna wire that lost contact with the DESS or some such. They replaced a couple on my first '11 RT. Make sure that "wire" is not supposed to be loose.
Did you try both keys and it wouldn't start? Just wondering if somehow, the chip in the key went bad>
