SNOOPY
AZCowboy: I believe you are right that wrapping the pipes will lower the temps under the tupperware. I am worried about what that will do to the longevity of the pipes.
Snoopy: The lines are 1/4 inch or 4.6mm running from the tank to the canister and then to the purge valve. The overflow is larger. I think it was 3/8 inch.
By the way I buy my hose clamps at the Home Despot in the plumbing section. I think they are better quality and less expensive than the clamps at the car parts stores.
Thank you, it is raining today so I may get a chance to look at mine a bit today.
I like the thought of moving it also because that side of the engine compartment is pretty tight w/ stuff and probably contributes to the concentrated heat.
I agree on the Home Depot clamps, they are all stainless, unlike auto parts stores Chinese clamps. And much cheaper than going to a marine store to buy.
