SportsterDoc
First fuel stop: Most of the miles were the Red Rock Canyon run after switching to iridium spark plugs. 65.4 miles / 1.785 gallons = 36.64 MPG.
Second fuel stop: Typical speed 55-65 MPH. 68.1 miles / 1.824 gallons = 37.33 MPG.
Third fuel stop: Interstate 15 at 70-75 MPH, with 15 MPH headwind. 55.3 miles / 1.731 gallons - 31.95 MPG.
The iridium spark plugs (NGK 4218) seem to make an improvement.
Wanting to switch to 10W50 for the summer, as the BRP XPS 5W40 is only rated to 104 F, today was oil change day.
Ryker went on ramps easily. Floor jack brought rear level.
Both engine drain plugs broke loose easily.
Magnetic drain plug had very little debris.
Oil came out darker than expected from dipstick readings.
The 2020 Ryker manual appears to be correct. 3 quarts out and 3 quarts to full mark on dipstick...but will check again, after an in-town run.
Replaced both 18 mm aluminum and 8 mm copper crush washers on engine drains.
While up on ramps, I went ahead and replaced BRP XPS 5W40 transmission fluid with Mobile One 75W140 for hot climate operation. Thanks to CanAmRyder for educating me on drain plug location.
Gearbox oil was ugly. Magnetic drain plug almost filled with goop. Cleaned with 1/8" screwdriver and brake cleaner.
Used Dorman 095-016 18 mm ID aluminum crush washer on trans drain plug, $0.69 each from O'Reilly Auto.
Makes me consider changing final drive fluid very soon. But, not easy with wheel on. Save that for another day.
Extremely glad that I did not wait until 6,000 miles for first engine oil change, nor 12,000 miles for gearbox fluid change.
