If you want to know about why
THIS thread got moved Dave, it was moved as it clearly wasn't about Spyders, so it didn't belong in
SPYDER General Discussion, but it
was about how the
Forum operates & apparently seeking support/advice on that.... so
Forum Support & Testing is far more appropriate for
THIS thread and that's why it got moved from where you originally put it. :thumbup:
But if you're asking about your '
Famous Quotes' thread (linked below) then it too should be pretty clear why it got moved from
Spyder General Discussion - it's gone into the same section/sub-forum that all the other
NON-Spyder/Ryker threads are in - the
Off Topic Board, which is where all things
NOT Spyder, Ryker, or Forum Support related belong. :2thumbs:
https://www.spyderlovers.com/forums/showthread.php?152298-Famous-quote
Re-directs were left for both of these threads, so all you need to do to see where they went is to click on the redirect, then when the thread opens, look up towards the top of the page to see where it is now - there's a listing that starts with the Little House/Home symbol & then lists on down thru the sub-forum chain until it gets to the actual thread title, so for
THIS thread, it shows:
Home; Forum; General Discussions; Forum Support & Testing; Moved. ;-)
If
you can just decide to post threads in whatever sub-form/section you feel like, regardless of what sub-forum or section they really belong in, then how can we expect anyone else to do the right thing and help others by at least
thinking about using the correct sub-forums? And if
no-one bothers to use the sub-forums/sections, then we might as well dump everything in Spyder/Ryker General Discussion where it'd all get jumbled in & likely lost amongst all the other non-related stuff! :yikes:
There
was a time that this Forum
did operate with far fewer sub-forums/sections, but many members (like you) clamoured for more sub-forums and extra sections to help organise things and put all the similar/related threads & common subjects/discussions into the same place to make them easier to find, so the Owners/Management of the Forum obliged, and it does generally work pretty well - has done for quite some time now. But it will
only continue to work if
All Members make at least a token effort to do the right thing, cos the Mod/Admin Team really don't have the time or the inclination to waste on perpetually cleaning up after those few who just have no consideration for everyone else. :banghead:
So, thank you for your consideration of all the other Members here by trying to put any new threads you start into their appropriate sub-forum/sections. Even if you don't often hear it from anyone, the time you take and your efforts to do this do help make the place easy to use for others and as such, are certainly appreciated. :thumbup:
