More add ons w/pix
Roger
I decided to remove the back fender so by doing this i had to relocate the plate which i used the one from Raw Design pricey yes but good quality also i can switch from horizontal to vertical in 2 seconds i also added their led plate light to keep everything legal. Some of you may remember i was going to change my body panel screws over to DZUS buttons well one side was done before winter so i started on the splash pan there are seven screws i only replaced 6 and left the far back one alone just for security reasons. It is going to gether pretty well you just may have to squeeze the clip a little just to make sure the button reaches the clip. I have more add on i will post when i'am done.
Roger, if you bolted the license plate bracket in to the hole where you removed the fender support, keep a close eye on the plate bracket. The vibration in that area is strong and will cause that metal fender support to break off sooner rather than later. Ask me how I know....
No not the case here alot of people don't know it but the back axle tube is hollow. So as per the instructions you take the bolt that is already through the new plate bracket and tap it in to the axel then while holding the bracket tighten the allen bolt and that expands inside the axle tighten firmly and waallaaa. But thank you for your concern. :2thumbs:
