JayBros
Well-known member
Found out late last week that Uncle Dudley's Postal Service hadn't lost my 2,000 mile sample of Mobil 1 4T Racing 10W-40. They just sent it via the far side of beyond before dropping it in Atlanta. Anyway, the report is attached and it looks pretty good. If you look at the report and verify the cSt 100C number of 12.5 against Bob is the Oil Guy viscosity chart, http://www.bobistheoilguy.com/viscosity-charts/, you'll see that the number equates to a very high 30 or very low 40. This is compared with my first and only analysis of XPS Semi-Synthetic 5W-40 that was done at 4,400 miles and had an equivalent mid-20 weight when I made the switch to Mobil 1. There is an error in the basic data section; I did change the filter but incorrectly marked the wrong box on the submission form. The only thing I find unusual in the report is there appears to be little if any viscosity shear and this does not square with the information Steve M of BRPcare provided in http://www.spyderlovers.com/forums/showthread.php?82580-Oil-Level-on that the oil shears down 20-30% in the first 1,000 - 1,500 miles. To what do I attribute this lack of shearing, I haven't the faintest idea and don't really care why it did not nosedive. The next analysis at 4,000 miles will be much more important because it will be closer to the mileage at which the XPS was analyzed. I will follow the results of the 4K analysis with a third one at 6K and based on that one will decide if I should do one at 8K or just go all the way to 9,300.
