mirror removal?
skypup
How do you release the tabs on the left mirror without breaking anything? The manual says to pull down on the bottom of the mirror to unlock the tabs and then lift up. No luck yet and I don't want to force anything. Thanks in advance.
Pull OUT on the lower half of the mirror. There are two posts near the bottom that snap into spring clips. Pull the bottom edge straight out to disconnect those two posts - roughly an inch, then slide the mirror assembly up to release the top post from a slot. The posts are hard mounted on the sides of the fairing, not the mirror housing. The mirror housing has the spring clips and slot.
Thanks for the quick reply. That really clears things up.:2thumbs:
